Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Tuning question
Old Feb 4, 2014 | 07:29 AM
dmracing's Avatar
Default Tuning question
This isnt a LS, but Im at a loss. I dont know if Im over looking something. Here's what going on. I built a 406 SBC gen 1 and its running. Sounds good, no smoking. I decided to pull the plugs just to look at them amd the outer 4 cylinder are running rich. They dark and dry, not wet. the inner 4 plugs are grayish. Look right, but the outers look rick. What do you guys think is going on?
Old Feb 4, 2014 | 08:18 AM
ZONES89RS's Avatar
In-Zane Moderator
What intake? Common for some I takes to cause distribution problems. Especially the older intakes.
Old Feb 4, 2014 | 03:44 PM
dmracing's Avatar
Its a copy of the Dart. The hurricane. It ran fine on the 383 it was on
Old Feb 5, 2014 | 09:06 PM
LXguy's Avatar
Brand new motor? Was it started and run around the block a couple of times or just idled?
Did you get it fully warmed up?
Same fuel as you used before? Same plugs?
Old Feb 5, 2014 | 09:44 PM
dmracing's Avatar
same fuel, same plugs. Idled in garage. It did get fully warm
Old Feb 6, 2014 | 08:57 AM
LXguy's Avatar
I'm assuming you've tuned the idle screws in for the new motor. Does the carb have 4 corner idle?
It might want a little more initial timing.
If your A/F (or vacuum gauge if you set it up the old-timey way) looks good, and if they're not dripping wet or fouled I wouldn't worry about it until you can run it around a little bit.
