Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
hard starting when warm
Old Feb 4, 2014 | 09:16 PM
billymgb1000's Avatar
Default hard starting when warm
ok I have a 4.8 fresh rebuild bearings, rings , cam and lifters I have an edelbrock 600 cfm and ngk tr55 plugs the cam is the hot gm kit with ls6 springs 219/228 .525 112 lsa now she fires right up when cold but when she is warm it turns over quite a few times and I have to put the pedal to the floor to start any ideas why
Old Feb 5, 2014 | 05:09 AM
Pop N Wood's Avatar
Almost sounds like a stuck choke (i.e. too rich). What are your air fuel ratios like? Black plugs or tail pipe?
Old Feb 5, 2014 | 06:37 AM
richard david's Avatar
Those edelbrock carburetors are notorious for that. I've had three or four of them over the years and all of them acted like that. Save yourself some trouble and by a holley.
Old Feb 5, 2014 | 07:35 AM
ZONES89RS's Avatar
In-Zane Moderator
Agreed. ^
How does it sound with that cam? I imagine it idles very nice.
Old Feb 5, 2014 | 10:33 AM
hey zones you are so right she idles awesome just what I wanted as far as the power it has been snowing since I finished putting her back together. so come on spring, thanks for everybody's input
Old Feb 5, 2014 | 01:09 PM
ZONES89RS's Avatar
In-Zane Moderator
Sound clip or it didn't happen.
Old Feb 5, 2014 | 01:15 PM
LXguy's Avatar
I would check the fuel line routing. You might also try an insulated gasket or spacer.
There are several things that cause hot start issues, but boiling fuel is probably the most common.
I agree on the Holley comments. You'll leave a a lot of power on the table with that Edelbrock.
Steve
Old Feb 5, 2014 | 02:28 PM
speedtigger's Avatar
Old School Heavy
Originally Posted by LXguy
I would check the fuel line routing. You might also try a insulated gasket or spacer.
I agree this is a good place to start.
Old Feb 5, 2014 | 09:03 PM
89gmcs15's Avatar
My hot start issue was mostly due to a rich idle afr. Idle timing and float level was another big one.
