What PCV valve for carbed use.
I'm in the process of reworking the pcv on my 5.3 foxbody. I tried running no pcv but the smell and fumes were terrible.
So I'm going back to square one and was wondering if there's a particular PVC pn# that's preferred. An inline one for 3/8" hose would be optimal.
I also wonder if it matters which valve cover I use for the pcv. I was using the drivers side port but the only place I had to mount my oil separator was on the passangers side fender. My pcv hose would be quite a bit shorter if I could pull air out of the passangers side valve cover.
My DIY catch can.
My DIY catch can.
![](http://i3.photobucket.com/albums/y96/krochus/mustang%20buildup/75C3B513-3B49-40A9-B840-7662C45BA47D_zpsrzwftdpa.jpg)
I use a Purolator PV1057. It is an inline like you want. I have the vacuum hooked to an LS6 valley cover vent with a cheap fuel filter on the valve cover vent for fresh air. The valley cover vent has some baffling on the underside to try and separate some of the oil
I found that the factory valve pulled too much vacuum and it caused my engine to idle higher now matter where I put it.. I run an Auto parts store so a few hours of digging thru boxes found me a valve that was a bit more difficult to open under vacuum and it solved my issue (cut oil consumption down too) I believe the valve is for a mid 70s Chevy straight 6 believe it or not
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I found that the factory valve pulled too much vacuum and it caused my engine to idle higher now matter where I put it.. I run an Auto parts store so a few hours of digging thru boxes found me a valve that was a bit more difficult to open under vacuum and it solved my issue (cut oil consumption down too) I believe the valve is for a mid 70s Chevy straight 6 believe it or not ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Right now I'm running a 70-80's 350 Chevy truck one
