Holley 300-131 LS3 Single Plane Manifold Compared to Edelbrock 28457 PICS
Isn't edelbrock still made in the USA as well as many others. Why would you even think of that China Crap. You get what you pay for. BUY AMERICAN!!!!!!!!!!!!! SAVE a JOB. Get the quality you and your hard earned money disserve. I will bet no one has a rotating assembly that's made in freaking China.
Both have one thing in common. FREAKIN CHEAP CRAP. You want to see what will take the abuse. Go talk to the dirt track guys. Modified or Late Model. Or maybe the Baja guys. They don't just run their stuff for a few seconds. They are screaming their guts out for 20 mins to hours. I'm sure you will find QUALITY parts like Callies, or Lunati just to name a couple. And they are not special just because their name is on anything. Its the same quality whether your a big name or just a guy with a hot rod. So don't be Naïve. YOU GET WHAT YOU PAY FOR!!!!! ALWAYS!!!!! Be Proud that we have the best products on the planet hands down. Keep our fellow Americans Working. Buy American.
That's why we went with the Callies Dragonslayer with their Ultra H-beam rods. All Forged and Completely made right here in the Good Ole USA. I know the rods are fordged in Trenton Mich. and the crank is either there or Ohio. This is also why we are on our third winter into this build. Lol Takes a little more money which translates into more time but IMO its worth it to invest in America. And the biggest thing is. If its a better product isn't it worth more time and money. Supposedly the Dragonslayer and the Magnum are the same crank. Just the Magnum has been gun drilled to lighten. Which actually makes the dragonslayer a stronger crank. Seen too many of my friends impatient to get their build done so went cheap and in not too long, BOOM. Rods hanging out the block, holes in the oil pans etc. This is why you see so many give up and abandon their cars, and the decline the amount of racers. They can't afford to start over and unless their ladies are very understanding, they sure don't have to deal with their women over again. (No offence to the ladies out there). You may just as well stay with the stock stuff. It is absolutely incredible what the guys on this site have done with OEM. Whether it be injected or carbed. Absolutely INCREDIBLE.
Does anyone have actual tests head to head or advice on these two EFI single plane intakes. I am trying to decide which is best to use on my LQ4 with 799 heads and TSP 228r/114LSA cam. The valve train and rod bolts have been upgraded and I will be using the Holley HP EFI controller, and the motor is in a 71 Camaro 4 speed. I understand the issues concerning low RPM torque are not in play so much with the EFI single plane configurations, although it seems in the carb version the Holley is better. Thanks for any help.
#32
Hey all.
Just got the Holley 300-131 LS3 Single Plane Manifolds, see below for pictures compared to an Edelbrock 28457.
$235 intro price for the Holley
Installation Notes
Carbureted, All GM LS Gen III LS3/L92 Single plane intake manifold. All GM LS Gen III or IV engines equipped with LS3/L92 style rectangular port cylinder heads)
Features
2500-7000 RPM power band
4150 Square bore flange
Optimized runner layout and constant cross sectional area - broad torque curve, best vehicle performance from 2500-7000 RPM
Minimum carb flange height - fit in vehicles with minimum hood modifications
Cast aluminum construction - great manifold for centrifugal blower, turbocharged or NOS mild power adder applications
Efficient casting design - lightweight, consistent wall thicknesses, improved casting quality
Height (front) - 5.417" to the lifter valley cover flange at the engine block front flange and bellhousing flange
Port size - 2.50" height x 1.15" wide
Mounting flange gasket type - o-ring
About 1" Lower carb pad vs the Edelbrock.
Attachment 606998
Edelbrock on Left, Holley on Right
Attachment 606999
Attachment 607000
Attachment 607001
Attachment 607002
Attachment 607003
Attachment 607004
Attachment 607005
Installation Notes
Features
Attachment 606998
Attachment 606999
Attachment 607000
Attachment 607001
Attachment 607002
Attachment 607003
Attachment 607004
Attachment 607005
#33
