intake/carb choice & size? Ly6 with cnc'd 821's.
corrisiveness?? serious. never had any issue in my previous late model efi engines and more recently in carb, with pump based high grade e85 (usually 90-92% ethanol).
you can run new style rubber hose and its totally fine (i use -8 and -10 push on hose with barb fittings), will get fumes through the hose, but with carb the bay will smell of e85 anyway. don't have to be bling bling and run the teflon lined hose.
i have run the gm dizzy front cover and also use a billet holly ultra hp mechanical alcohol pump rated at 225 gph and it works a treat, with engine up around 570hp. i use a custom e85 carb by eric at horsepower innovations, top top guy that only does e85 carbs 9hi eric if you are reading)
If you use rubber hose designed for ethanol content its fine, but try using some cheap azz walmart rubber hose and it wont hold up. It will start eating the hose away slowly. Eric L
