Carb tweak
So if you have too little or too much of the transfer slot showing at idle it won't transition well.
Second, I agree with you the air bleeds are suppose to flatten out the AFR as air flow increases. Some links say "delay", I'm not really sure which is correct. But I do know from basic physics that without an air bleed the AFR will get increasingly more rich as the air flow increases. So what I do with the transition and main circuits is set the AFR at the low end of the band with the jets/IFR, then adjust the air bleeds if it goes rich/lean at the top of the band for that circuit.
Again, Speedtigger says "it's not that simple", but I have had pretty good luck with this approach. I am often in 5th gear before 30 mph. I can cruise in 5th gear at 1000 RPM.
Float levels
Transfer slot within range
Secondary linkage functioning properly and adjust correctly
Accelerator pumps adjusted properly
Proper jets and powervalve (factory calibrations)
I also agree that in general the IFR will affect the low RPM cruise A/F ratio more while the LSB will affect the higher RPM crusie A/F ratio more.
Have a look at my answer above. They are related like you suggest, but they are biased like Pops mentioned. So, you might think of them as a pair. A smaller IFR and LSB package could tend to lean out the bottom while still having a similar ratio to one another as opposed to a larger IFR and LSB package can maintain the same ratio to one another while being richer down low.
