Carb tweak
It's a $5 part worst case scenario you try it and it tells you your problem is powervalve related or not. If you block the PV and the overly rich condition goes away then you know you need to either go to a delayed power valve or start cutting back on the PV enrichment jet size
I assume you checked the float levels and fuel pressure. also all the gaskets good, power valve torqued down nice and tight. Check all the air bleeds for obstruction (blow compressed air through them or chase them out with a piece of wire).
If all good find your idle feed restrictors and make them smaller. IFR are like main jets for the cruise circuits. Look at post #18 in this thread
https://ls1tech.com/forums/carburete...ce-needed.html
from what i've read on the interwebz... If it goes rich to lean then you need to put in a bigger IAB to delay the circuit flow.
everything on the internet is correct....bonjor
sorry i'm still trying to wrap my mind around everything. is the above statement true? i know the tech at QF told me to reduce the IFR size, but i'm reading conflicting information on the web.
". The IFR is the gatekeeper of fuel for the idle/cruise circuit. Experienced tuners decrease IFR size when they need to reduce idle/cruise below 1/2-3/4 turn from fully closed in order to get 14:1 air/fuel ratios at those speeds. The IFR is flooding the idle circuit with fuel and causing the idle and cruise to saturate. Alternatively, tuners can increase IFR size if the engine is starving for idle/cruise fuel (beyond 2.5 turns out from fully closed/seated idle/cruise screws to keep the engine running). "
