Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
programming msd 6010
Old May 31, 2014 | 07:51 PM
tom70's Avatar
Default programming msd 6010
When I program my msd 6010 box do I have to power up box
Old May 31, 2014 | 10:59 PM
89gmcs15's Avatar
Yes. It wont show up on the computer if you dont. If youcant bring your computer to the box ive used a jumper wire and a atv small battery to power the + pin
Old Jun 1, 2014 | 04:38 AM
Doug G's Avatar
Yes, Key on / motor off.
Zero out the MAP until you're ready to adjust later
Write your timing (Place the dots where you want and save as _____ )
*Don't forget to adjust rev limiter....ask how I know
Now plug in your laptop to the MSD
Turn the ignition on to run position (do not start motor)
Open the file you want/just wrote
Transfer computer to MSD (all files) *watch download bar for completion
Now you are ready to start motor
Old Jun 1, 2014 | 07:27 AM
tom70's Avatar
Thanks
Old Jun 1, 2014 | 09:21 AM
ZONES89RS's Avatar
In-Zane Moderator
I open the MSD and make adjustments and then plot to MSD.
Old Jun 2, 2014 | 08:27 AM
tom70's Avatar
any suggestions on timing for initial heat cycle?
Old Jun 2, 2014 | 08:31 AM
ZONES89RS's Avatar
In-Zane Moderator
Nope, set it in the ball park and drive it. 32* is usually a safe number for max WOT timing. From there tune it out.
Old Jun 8, 2014 | 02:20 AM
R. Finkle's Avatar
Hopefully you got this figured out. Like they said, use jumpers to the pink and grey wires, + - accordingly. plug it in the comp and go. It should load automatically when powered up. It sucks not having a laptop to program that thing... I know.
Old Jun 8, 2014 | 07:23 PM
tom70's Avatar
Can't get mad box to communicate with laptop can't get program to notice usb port only allows me to choose comport 3. Useing usb to nine pin cable. Any sugestions
Old Jun 8, 2014 | 07:53 PM
dealrcn's Avatar
Do you have the usb to 9 pin serial adapter? If so it should be able to communicate using the com3 option.
Old Jun 8, 2014 | 08:27 PM
S10xGN's Avatar
Open Windows device manager and note what com port is assigned to your cable, then open Graphview and select the correct com port there...
Old Jun 10, 2014 | 12:49 AM
R. Finkle's Avatar
watch this and follow along. Fixed my problems...
Troubleshooting the USB to Serial Port Connection
Old Jun 11, 2014 | 02:40 PM
h8tulooze's Avatar
I went on MSD forums and they have a video on how to fix it. I had to use a Vista Laptop to get mine to work.
Old Jun 13, 2014 | 05:59 PM
R. Finkle's Avatar
See post #12...
