Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
plugs for FI holes
Old 08-31-2014, 06:28 AM
forcd ind's Avatar
Default plugs for FI holes
I have a Holley FI throttle body intake I am going to use a carb on
I need to plug the injector holes, looking for ideas on plugs
it will be boosted, so I need some kind of "swell" plug or something
anyone done this
Old 08-31-2014, 10:13 AM
LS1-450's Avatar
anyone done this
Tap the holes & use screw in brass plugs. Could also size the holes to accommodate pressed in freeze plugs.
Old 08-31-2014, 11:05 AM
forcd ind's Avatar
I want to keep the integrity of the holes, just in case
Old 09-01-2014, 10:23 AM
LS1-450's Avatar
Could fill 'em in w/ an epoxy that can be removed w/ high heat. Splash zone marine epoxy has been successfully used in plastic manifold repairs. I'd say JB weld could work on an aluminum manifold. That's all I got short of making your own plugs using stock "o"-rings on a grooved rod w/ a cap on the end to make it look better.
Old 09-01-2014, 11:20 AM
383lt1impala's Avatar
i put dummy injectors. people would ask are you carb or efi? or both lol
Old 09-02-2014, 12:20 PM
Prorac1's Avatar
Just get some expandable freeze plugs. You know the kind that you screw down the set screw to expand the rubber. That's what I would do. Maybe seal them with some grease when you put them in and check for vacuum leaks when done. Eric L
Old 09-02-2014, 04:25 PM
Doug G's Avatar
Would be really nice to plug them with a direct port kit
Quick Reply: plugs for FI holes
