Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
compression question
Old Sep 23, 2014 | 09:12 AM
fast89stang's Avatar
Default compression question
If we have lq9 and stock pistons, milled heads. 050, how much comp should we have? Building a max effort lol another one, for another buddy. Looking to get cam ideas from tooley or tick or? ??? Somebody Soon.
Old Sep 23, 2014 | 10:32 AM
dogsballs's Avatar
I go roughly 0.6:1 per 30thou.
So guess up 1.0
Or cc heads and do it properly
Old Sep 23, 2014 | 02:53 PM
Doug G's Avatar
.006 per cc and measuring them would be the right thing to do.
Running the numbers and shavin' .050 I' m looking at 11.3:1 with everything else stock. Approximately
Old Sep 23, 2014 | 03:19 PM
speedtigger's Avatar
Old School Heavy
So guess up 1.0
I find it better to do it the way Doug said as the compression change per thousandth goes up as the compression ratio gets higher.
Old Sep 25, 2014 | 06:30 PM
Sales@Tick's Avatar
You know how to get a hold of me sir!
Old Sep 25, 2014 | 07:17 PM
Old School Heavy
If you are using an LQ9 with Stock 71cc heads. My figures look like this:
So, 11.05:1 using the oft quoted .006" milled off = 1cc formula.
Last edited by speedtigger; Sep 25, 2014 at 09:36 PM. Reason: Cuz I got it wrong initially too! LOL
Old Sep 25, 2014 | 07:27 PM
Doug G's Avatar
Steve, to keep my math easy, I just input all the stock info and then reduce the gasket by the thickness to be milled. Kind of a down and dirty method. LOL works up to a .050 cut
Old Sep 25, 2014 | 08:55 PM
Old School Heavy
Don't be mad for me saying, but that is why you got it wrong. If you notice, the combustion chamber does not take up the same amount of surface area as the gasket.
Old Sep 25, 2014 | 09:19 PM
The stunningman's Avatar
speed is right about the gasket giving more than the mill. However stock diameter isn't 4.060 on a GM 6.0 head gasket. Its closer to 4.100. On L92 heads the edges of the head chamber are larger than a 4.060 gasket (not that it presents a problem). The GM 6.0 gasket is larger than the chamber.
Old Sep 25, 2014 | 09:44 PM
Old School Heavy
Depends on which gasket you have. The 12589227 is the original ls2/LQX series head gasket which I believe is 4.060". The 6.2 liter LS3/L92 gasket has a larger bore and is part number 12610046 which I remember being 4.080". I have used both. Then there is the 12622033 LS9 head gasket that is advertised as 4.100"(I have never tried that one). Either way, it only makes a few hundredths of a compression point.
Old Sep 26, 2014 | 07:26 AM
Doug G's Avatar
The calculator I used doesn't ask for a gasket bore diameter. So not taken into equation.
You have the deck height at -.006....I used 0. I see this is where the difference comes in.
I adjusted the one I used to input a stock LQ4 compression of 9.43:1, that is where I got the 0. With the -.006 I get 9.55:1
I also have to ask...with the combustion chamber shape being what it is, how can a single number (.006) equal a set amount of increase ?
I can see it to a point, but wouldn't it increase once you get past that point ?
So, yes, really should measure to be sure.
No argument here, and no feelings hurt.....I'm not a machinist by trade
Old Sep 26, 2014 | 08:13 PM
i think this project is put on hold. We have taken apart 2 motors, one had a broke crank and the block was damaged. The other had a busted piston and had some cylinder damage. I found him a LY6 on Ebay for 1750 plus 175 shipping, but he didnt buy it.
