Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
2000 z28 question
Old Oct 5, 2014 | 09:48 PM
stang357's Avatar
Default 2000 z28 question
Well I converted my z28 to carb and I'm battling issues with my fuel pump.....I'm currently using the stock fuel tank and sender and have a externally mounted Holley blue....it doesn't seem to be cutting it....any recommendations on a external or internal low pressure pump ?
Old Oct 6, 2014 | 01:24 AM
ZONES89RS's Avatar
In-Zane Moderator
You still have the in tank pump?
Old Oct 6, 2014 | 04:53 AM
stang357's Avatar
i was just using the float and sender but yes I still have it
Old Oct 6, 2014 | 08:08 AM
tim burks's Avatar
have you got the holley pump pulling through the old pump? I know your old pump is disconnected, but is the holley pulling through it by the original fuel line.
Old Oct 6, 2014 | 08:41 AM
stang357's Avatar
I have the sender and hanger but the old pump is taken out
Old Oct 6, 2014 | 10:37 AM
tim burks's Avatar
whats it doing? are you losing fuel pressure?
Old Oct 6, 2014 | 10:53 AM
LLLosingit's Avatar
How close to the tank is the pump? is it located lower than the bottom third of the tank?
These pumps are not good for pulling fuel so they need as little restriction as possible on the input side.
