hit up the track
i discovered a problem. my truck won't shift to 2nd at WOT. it's probably been doing this since day 1. anyways I drove in, teched, drove straight to the line and ran a 6.80@101. 1.46 60' shifting 1st to third.
the sun went down and the traction went away. a few 1.75 60' times no matter what i tried. guess drag radials dont like the cold becuase i didnt see anyone else hooking on radials. slicks were still sticking.
anyways i spent the entire night chasing traction and trying to get the truck to shift into 2nd gear at WOT. a ton of 7.20 slips with shitty 60' times. it ran a 7.5 shifting first to fourth lol. pissing me off as usual. i'm curious how it will run with 2nd gear LOL.
anyone know what would cause a 65e to not shift 2nd gear at WOT? I think my converter is throwing the trans controller for a loop. it is basically at 7k rpm as soon as my foot hits the floor. the shift drop back is 7,000 to 6,000 shifting to 3rd instead of 2nd.
anyone know what would cause a 65e to not shift 2nd gear at WOT? I think my converter is throwing the trans controller for a loop. it is basically at 7k rpm as soon as my foot hits the floor. the shift drop back is 7,000 to 6,000 shifting to 3rd instead of 2nd.Trending Topics
i haven't calculated the slip, but once at 6k rpm and up it does its job. from a dig, i don't mind being between 6k-7400. the converter was supposed to be a 4,500 but that isn't what i got lol. it drives nice and launches hard N/A so i kept it around for a while. i knew i would have to eventually remove it, and the builder told me that he will rebuild it until I'm happy. I'm just not sure I'm willing to remove and install that many times lol.
i have a few things to try. i don't think the problem is within the transmission at all. it shifts fast and firm (not to be confused with harsh) at all times besides WOT. it has to be in the tuning, or the aftermarket ECU not being able to react fast enough to the converter. the transmission was originally a LVL7 FLT transmission that i sent back to the original builder who no longer works for FLT. he upgraded the LVL 7 with parts that weren't available to the market when the transmission was originally built. smart-tech aftermarket input housing, billet apply pressure plates, a new sonnax drum, the trans brake, Billet reverse input drum spring retainer, billet pump rotor, and a deep pan. it's as built as a 65e can be built at this point i guess. the builder wants me to log the solenoid operation while at WOT to see if the computer is commanding a 2nd shift, or a 3rd shift to start a process of elimination on what's actually causing the missed shift.
