Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Daytona Sensor Box
Old Apr 19, 2015 | 02:06 PM
TA_BUD's Avatar
Default Daytona Sensor Box
anyone using one? on facebook called (Carb LSx Swaps) running a special discounted price if we get 10 or more buyers.... which I think we have.. it replaces msd box 6010 and 6012 it also has adapter cable to replace msd..hooks up via usb port not serial port
Old Apr 20, 2015 | 02:34 AM
Mrmooney's Avatar
Any idea on price?
Old Apr 20, 2015 | 03:13 PM
axe murderer's Avatar
I'm in on it, today was the 1st day & I'm # 5 & they need 10 for the deal, they shouldn't have a problem getting to the minimum.
Seems like a good price, they're not posting prices only get them by PMing the guy in the group promoting the group buy.
Price depends on what you need, I bought the module & harness to adapt it to the MSD harness since I already have the MSD. they sell a full harness if you don't have the MSD.
The shop selling them isn't a vendor here so he doesn't want to advertise it here.
Old Apr 20, 2015 | 03:31 PM
Doug G's Avatar
So you need the MSD also ?
Does it do only carb or EFI....or either ?
Do they have a stand alone system "like" the MSD ?
I'm confused
Old Apr 20, 2015 | 03:43 PM
I'm confused
Carb only, don't need an MSD box but if you have a MSD harness already you can use it with an adapter.
I have the MSD harness so I got the adapter, was less than half the price of a complete harness & I still have the option to use the MSD.
My car is a track only car so I figure it's smart to be able to run both, if one has a problem @ the track I can swap them.
One thing that's cool is the box internally stores 10 program & has a selector switch so you can change them without a computer which might help @ the track.
Old Apr 20, 2015 | 05:35 PM
Doug G's Avatar
OK, thanks
Old Apr 20, 2015 | 10:15 PM
1973 STEP A SIDE's Avatar
Features
· Upgrade for MSD® P/N 6010 and 6012 ignition controllers.
· Ignition module for carbureted GM LS series V8 engines with 24 or 58 tooth crank trigger.
· Selection for GM LS1 or higher energy LS2 style coils.
· Preprogrammed with advance tables suitable for a wide range of normally aspirated high performance engines.
· Digitally set launch, burnout, and maximum RPM limits with 100 RPM steps from 3,000 to 9,900 RPM. Access to launch and burnout RPM limits requires optional USB interface and PC Link software.
· USB interface and PC Link software allows programming a custom 3D advance table based on RPM and manifold pressure. SmartSpark Log software displays real time engine data during initial setup and dyno tuning.
· Individual cylinder timing (ICT) capability with RPM based offset up to ±5° with 0.1° steps.
· Three general purpose input terminals. Inputs can be used for RPM limits and multiple retard functions including driver adjustable retard (requires optional RTD-1). Mode switch allows selection of basic functions. Advanced features require optional USB interface and PC Link software.
· Status LEDs show trigger inputs.
· Fully encapsulated construction without any internal voids.
· Heavy duty 12 pin Deutsch connectors used for signal connections.
· Same mounting pattern as MSD® P/N 6010/6012. Compact size: 6.0”L x 3.5”W x 0.63”H. N
· New installations require wire harness P/N 119002, 119003, 119005, or 119006 depending on mounting location. For upgrading existing MSD® P/N 6010/6012 installations, use adapter harness P/N 119004 . Ne
Old Apr 22, 2015 | 08:09 AM
redline2k's Avatar
The daytona box has many extra features over the MSD. It works with both 24 and 58 tooth cranks. Has individual cylinder timing. Connects via USB. You can load more than one custom tune into the box and change with the rotary switch on front of box. Has burnout limiter, Two step, and timing retard outputs. Testing has shown timing at higher rpms to be more stable than msd box.
Can change tune or rev limiter without laptop if needed
Full Harness
MSD Adapter Harness
Old Apr 22, 2015 | 09:25 AM
Mrmooney's Avatar
Edit was cleared up on Facebook
Old Apr 23, 2015 | 09:11 AM
speedtigger's Avatar
Old School Heavy
I will be doing a head to head, Daytona Sensors' Smart Spark VS MSD's 6010 coming up very soon. I will have a full write up on it for you all.
It will cover: features, ease of use and performance track test.
Old Apr 23, 2015 | 09:11 PM
TA_BUD's Avatar
Default boxes
speedtigger that will be awesome im new to all of this and appreciate any input from anyone with knowledge..at the moment im collecting parts for my build hope to have it going by june 1st
Old Apr 23, 2015 | 11:29 PM
Mrmooney's Avatar
Great cant wait still deciding on my build
Old Apr 24, 2015 | 08:27 AM
thirdgenbum's Avatar
i'm just here to watch how it goes. this is on my list, but will have to wait till the winter when i finally rewire my car properly.
Old Apr 24, 2015 | 03:15 PM
Doug G's Avatar
Are we done yet ?
Old Apr 24, 2015 | 03:40 PM
franktf's Avatar
I am very interested in this info, I have been looking at Daytona Sensors box for my project.....
Old Apr 30, 2015 | 09:52 AM
redline2k's Avatar
I know about 14 cars that will be running them soon!!!
Old Apr 30, 2015 | 06:07 PM
Doug G's Avatar
So... if someone wanted/needed to go to the Daytona box....all that would be needed is the box and an adapter ?
That's great
Old Apr 30, 2015 | 06:21 PM
That's great
That is correct !!!
Old May 1, 2015 | 07:00 AM
That's great
yup that's the truth. however, with as many problems as i and others have had with the msd box, i intend to get daytona sensor's harness as well to eliminate any possible variables...but the option remains open to those that don't want to rewire their car.
Old May 1, 2015 | 07:59 AM
Doug G's Avatar
I do like the look of their wire wrap better too....but may have to do in steps ?
