Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Carb help please
Old Apr 20, 2015 | 09:37 PM
jerr6's Avatar
Default Carb help please
I need to get a carb for my build. I know I need some where between 750-850cfm. My engine specs 6.0/821 heads/ Vic jr/ 227/242 cam. I read carb descriptions and they list all these features like 4 or 2 corner idle/ something about metering blocks. Vac/mech secondaries.
Do I just need a plain ole 750 double pumper?
I came across a nice used quick fuel slayer series 750 vac secondaries. Will this work good for mainly spirited street driving?
Old Apr 21, 2015 | 06:01 AM
RabidStreetRacer's Avatar
Yes the quick fuel 750 will work for like you said "mainly spirited street driving"
Vac secondaries means that the back 2 barrels open up at a certain time and during WOT, at a certain vacuum set by a spring. Mechanical secondaries open the secondaries as soon as you hit WOT, there is no delay. This can be good for race but can cause a bog to a heavier vehicle or one not set up for such a quick hit.
Vac secondaries are great for heavier vehicles, mechanical for lighter and race vehicles.
The difference between the 2 or 4 corner idle is tuneability. 4 you have more tuneability, but you will be fine with 2.
Metering blocks, holley 4160 series carbs have a metering block for the primary side and a metering plate with NON adjustable jets, 4150 series has a block on the primary and secondary so you can jet both sides. I had a 4160 modified to a 4150 by removing the secondary plate and adding a metering block.
Old Apr 21, 2015 | 07:34 AM
1973 STEP A SIDE's Avatar
Check this page out
https://www.facebook.com/groups/437900819710439/
