Drag racing w/ moroso 20143 oil pan?????
Moroso classifies this pan as "road race". I like it for 2 reasons. 1) the oil filter mounts on the rail no relocation needed. 2) it's a 7 quart
http://www.jegs.com/i/Moroso/710/201...oductId=763994
As far as oil filter on the pan rail pans go options limited
Anybody drag racing with this pan?
I currently have a stock f body pan. No modifications. Car is street strip. Nothing crazy.
365"
243s
CM big lope
Victor jr
Th400
I'm not expecting to pull the wheels through the 60
Is an F body pan good enough?
365"
243s
CM big lope
Victor jr
Th400
Old School Heavy
365"
243s
CM big lope
Victor jr
Th400
365"
243s
CM big lope
Victor jr
Th400
I don't see anyting in the design of that Moroso pan that would indicate it will not work for drag racing. But, I have never used it.
Speed trigger what pan are you using? My car is prob a 10.80-11.0 car. Not sure if it will leave hard enough to have a problem. Car does have great drag suspension as it used to go a lot faster. I'm running a melling std volume high pressure pump. I wonder if some fbody oil pan users having trouble are running high volume pumps. I was told to run a 6.5 quarter total system with the fbody pan. Read about some guys running 7
i'm using a 20140 with a relocated filter. i have video showing a 40psi drop in oil pressure on the launch with a stock f-body pan. with the new pan it's rock steady. the 20142 is exactly the same as i have and is listed as an f-body replacement and has the filter in the stock location. the only difference i see between it and the 20143 is the front portion of the pan is level with the pan rail on the 20140/20142, where the 20143 is sloped back to the rear sump. any of them will work great.
