Miss firing
Miss firing
Is anyone having this problem? I have the msd 6010 box car started running rough a few days ago checked it out found the whole bank 2-8 not firing replaced spark plug wire swap coil assembly from one side to other doesn't change checked power and ground on connector good running out of ideas
I had exactly the same thing. One of the female harness terminals was sloppy. The Chinese MSD harnesses have quality control issues .
I fixed it by bending the terminal closed with a screw driver.
Too check leave the motor Idleing and give all your plugs a tap or wriggle too see if the engine starts too putt out .
A lot of guys race out and buy new boxes for no reson at all.
