busted ls
Expensive failure I would imagine.
How does he know it was detonation and not something like a piston failure or piece of debris/valve hitting the piston?
Also you would see it in the other cylinders
I would think....
ring gap too tight, butted, and the rest is history
bad piston from the get-go
piston came out too far at the bottom
just to start with
Something went wrong... something wasnt right for that kind of damage.
My 5.3 is making power in that neighborhood on 30 degrees total. Its seen 38 degrees total and no speckling or detonation that i could see
What heads and CC chambers do you have?
100LL AV gas is going to leave speckling but not metal speckling.
AV gas burns real dry and anyone running that stuff has better be spiking it with a oil such a Marvel Mystery oil. I have heard of instances of it siezing valves in the guides.
At 11.5 to 1 you should be fine with 93 octane pump fuel. However if you have a set of 59 or under CC heads you could be as high as 12.5 to 1.
It's really hard to believe you busted a hole in the block with a forged piston because they don't shatter (unlike hyper). Most of them you can beat with a hammer into a ball. That seems like maybe the ring gap was messed up and maybe you broke the piston top somehow.
What jets were in your 850? Power valve's? Heads messed up bad? Valves bent?
You had something else happen.
What a mess. Maybe the 650 springs need replaced with something in the 700 range to give yourself some margin there. Check with a cam expert most springs are rated with stock rockers I believe which weigh less over the valve. Check the reluctor clocking just as a preventative measure to make sure it's where it should be. IMO you definitely had detonation and most likely due to the lean condition. I would jet the carb 87 square with no power valves for your next venture and tune from there. Better rich than lean as you now know.
Leave the AV gas at the airport.
