Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Best method for trimming the cowl??
Old May 24, 2016 | 07:33 AM
Dark SS's Avatar
Default Best method for trimming the cowl??
If I'm in the wrong section, I apologize but I figured this is where I would get my answer. I have recently decided to take the plunge and go with a vic jr., accufab 4150 set up. I am about to start to clearance the cowl. I would like to do minimal cutting and retain my wipers. I have seen it done where you have to just cut off 1 pass side wiper bolt. I would also like to be able to run some sort if filter or carb hat and cone on the street. I plan to buy a vfn 4" sloped WS6 so hood clearance won't be an issue. My question is what is the best tools and methods used to cut the cowl? I heard if you're not careful you can break the windshield and that has me spooked now.
Old May 26, 2016 | 04:00 AM
ZONES89RS's Avatar
In-Zane Moderator
I did a carbed 357 CI SBC years ago. I used a cut off wheel. Just took my time and went to work. On the small block big block section I did a thread I'm sure.
Here is a reference to where I cut
Old May 26, 2016 | 04:01 AM
ZONES89RS's Avatar
In-Zane Moderator
May look excessive but I was installing a distributor back there as well. Lol
