BLow threw carb what fuel pressure?
Ian anyone else running a blow threw carb setup? I modified my carb with the instructions from hangar 18. Today was first time at the track and it seems to run out of fuel pressure. So I added up to 9lbs fuel pressure from 6.5 and it made a pretty big difference. Now my question is what fuel pressure are you guys running on a blow threw setup?
What Gametech said.. Mine is 6.5lbs at idle with an aeromotive boost bypass regulator. that should be about normal. Too much pressure at idle with cause issues with your floats as well.
