Idle timing control MSD box 6014??
I have the MSD box 60143 Black and trying to find out what does the idle timing control do? It says I believe enable or disable I think? If I enable it do I need to go to a graph? I do have my map sensor hooked up. I couldn't find any info on it. thanks
From what I read, it constantly searches for the best idle timing, when it is enabled. Everything I have read, says to keep it off for high performance apps.
177 bbc
I need help dialing in my timing if someone could help I have a 454 bbc with a 177 b and m 6 btm box with the retard dial I need some knowledge on this where to set my timing and how to use/when to use the dial thanks tons
