Please help! Msd 6014 cam sensor fault
Hey guys I have been trying to chase down a cam sensor fault issue. My 6014 msd box been giving me a cam sensor fault. So I tried 2 used cam sensors (that came out of running engines) also a brand new cam sensor. After all of that I still am getting a cam sensor fault code. So I ended up going through all of the wiring they installed in the premade harnesses. All the wiring connections and harnesses are correct. (I was hoping to find something that wasn't right that was triggering a cam sensor code but everything was right). I keep getting a cam sensor fault code and the car breaks up and isn't running correctly.
I changed all the coil packs and plugs and plug wires and still same thing.
I also traced down all my coil pack wiring to make sure it was correct and it was. So I honestly have no clue what to try next. Any suggestions?
The following users liked this post:
Kyle Garner (09-17-2020)
The cam sensors for the 24x and 58x reluctors are wired differently. I think the outer two wires are swapped. The pins are labeled right on the sensor.
Other than double checking that I'm not sure what else there is to do. If possible try the I assume new box on a different motor and see if that is the issue.
I am pretty sure it's wires correctly the 12volt wire is in pin C and the sensor wire is in pin A and the sensor ground is in pin B. I currently don't have any other motor I can test this ignition on. I also don't have a extra msd box I could throw into my car and try.
Do you have 24x rear cam sensor, 58x front mount cam sensor. Sounds dumb, but the box should have come with 2 harnesses, one for each? "The car breaks up and isn't running correctly." This I think points more in the direction of wiring than cam sensor since the cam sensor is not needed while the engine is running. If I'm correct it's only used for startup.
did you ever figure this problem out I’m having similar issues keeps throwing cam sensor issue motor starts and runs fine until WOT and then it brakes up back fires seems like it looses a cylinder or two but As soon as I flip the ignition switch. Off then back on it runs fine. Unless I put another load on the motor
OP hasn't been here in almost 3 years.
