testing the theory
Long time ago I was told by an old timer that build pro stock & boat racing motors, I remember him saying iron holds the btus in better generating more horsepower.
I guess if you're racing PS where everyone is 2350 it makes sense to use iron.
Most of my stuff is aluminum but if I was starting from scratch & going to use some kind of power adder I'd do an iron 6.0 for the cost & wall thickness.
Long time ago I bought a car off here with a broken 6.0 that was sprayed pretty heavy, rocker arms failed but when I pulled it apart it was .060 over.
Unless you're making 2000 HP or racing in a very very tight class, then you're just splitting hairs with the aluminum vs iron argument and wasting your own time.
You might gain 6 HP with improved ring stability on an iron block. Its not even worth mentioning most of the time, and it doesn't compensate for the weight difference.
2036 feet @ 7 @ Memphis
@ 8 Density Altitude: 2279 feet
@ 11 Density Altitude: 2872 feet
http://www.dragtimes.com/da-density-...calculator.php
