need timing advice???
I would say to try a few settings to see what it wants.
Also, was this at the same track, or elevation ? DA will effect the ET/MPH
The common "trim" for the 58x (60-2) is a + 1.75*.
The common "trim" for the 24xe is +11* to +13*.
The LS front pulley has NO key and is unmarked, a problem.
The 6010 "tech" states "use with 24xe"
I would do a TDC "0" AND a 30* pulley/cover mark.
Lance
i always thought 35/36 was giving me best mph but when i checked plugs they always looked over timed. so i just dialed it back a little.
Pantera EFI whats the term "trim" and the numbers mean?
The OP IS OFF TRACK.
The thought of a quality build @ 39* = ENGINE DESTROYED
( NO blame to the OP)
What I state is the TDC "0" reference is OFF when MOST aftermarket Ignition/EFI systems are fitted.
The GM EMS uses a method to find the best Spark Instant, NOT a TDC reference.
The good "tech", your posts (DOUG), my "tech", is to find TDC "0"
I MARK the Crankshaft Rear Flange/Read Seal Cover after the Short Block is assembled for TDC "0".
WHEN I state this on LS-1 Tech, many here call me "IDOT" OR "GAME OVER"
ALL QUALITY engine assemblers will mark the engine for TDC "0", the test !
Lance
