Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
408 build
Old 02-28-2018 | 05:47 PM
Dragway's Avatar
Default 408 build
building 408 prc 225 heads 10.25-1 comp call. Brian tooley he suggested this cam ls3 stage 3 cam 229/244 .615/.595 113+4 looking for thoughts on cam with carb setup mainly 113 lsa
Old 03-02-2018 | 10:52 AM
pantera_efi's Avatar
Default LSA for a Carburetor
Hi, I worked with PML when we created the GMPP line of LS Carb intakes.
We FOUND a difference in LSA requirements when EFI/Carb choices are made.
I agree with BT about your lobe duration/lift AND state the LSA is more directed to EFI.
My specification is the same Lobe with a 108 C/L.
The reason is that a carburetor fitted to the intake manifold has a great amount of Tau fuel or "wet" port walls.
The FIX is to fit a camshaft with greater Overlap that will "clean" the intake port walls.
Lance
Old 03-02-2018 | 12:56 PM
neblackshirts's Avatar
Lance
Lance, you have an amazing vast knowledge in the automotive field. Enjoy reading your excellent explanations with good details. It's nice to read and see someone like yourself always willing to help out others!!
Old 03-10-2018 | 06:14 AM
Dragway's Avatar
Thanks for info call BT and got a different cam went with the cam motion stroker cam 246/254 621/604 with a lsa 110+4
Old 03-17-2018 | 09:36 AM
toxic99's Avatar
Should run real good with this cam...
Old 03-18-2018 | 11:36 PM
Bowtiedford's Avatar
sounds like a nice cam, I also went with a Cam motion cam for my 403. but a lot bigger lol. should be a screamer, good luck
