Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
E85 jet help
Old Mar 21, 2018 | 09:57 PM
rick539's Avatar
Default E85 jet help
Need recommendations on jet size.
5.3
Stock heads
Liljohn stage 2 cam
CSU 750 e85 no power valve (race only)
S475
Just need a reference starting point. Thanks
Old Mar 22, 2018 | 08:41 AM
Bowtiedford's Avatar
What jets does it have now? do you have a AFR gauge? Reading plugs on E85 will look like your LEAN lol, super clean fuel. My 428 had 92 front 102 rear with a 55 power valve up front. AFR gauge will be your best friend with E85, or use your temp gauge and see how much hotter the motor is after your pass. Old way of doing it but don't rec it.
Old Mar 22, 2018 | 08:45 AM
Ah just saw the S475' turbo right? Start rich and work your way down then. Running lean on a turbo motor going into boost is a sure way of self destruction. AFR gauge for sure then.
Old Mar 22, 2018 | 07:56 PM
rick539's Avatar
This is a new set up. Have AFR guage' just was hoping for a starting point. Was thinking about mid 90 range and start from there.
Old Mar 22, 2018 | 08:02 PM
rick539's Avatar
I'm pretty up on E85. My bracket car is a N/A SBC 383 at 600 hp. Your right about the plugs. Don't have AFR on it, but use my temp during runs to guage where I'm at. If I pick up 8-10 degrees at the end oh the run I'm about right. It's important that you stage at 170 to get best atomization of E85.
