Air bleed question
https://www.mcmaster.com/8455a16
https://www.micromark.com/The-Rogers...YaAsGYEALw_wcB
Put one of the brass set screws into a variable speed drill and turn it slowly. Get the correct size drill bit into the pin vice and using WD40 drill out the set screw to the restriction you need. Install in the carb with a little blue loctite.
Lots of write ups on it out there
