MSD 6010 Rev Limiter Chip
Those "chips" aren't rev limiters, they are entire timing curves. You need a lap top to adjust the rev limiter on the 6010 boxes. The lap top will let you set the whole timing curve. Throw the "chips" away and set everything up with the lap top.
And yes, the rev limiter set through the lap top works perfectly with the 6010 boxes.
Really pretty easy.
Add some dots to your timing curve, adjust your rev limiter, add some dots for the MAP (vacuum advance... if you use it)
Top ot the page has a lot of good reading about timing
https://ls1tech.com/forums/carburete...iming-set.html
