Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
408 misfiring at higher rpm
Old 11-06-2021, 06:24 PM
Rpayne41985's Avatar
Default 408 misfiring at higher rpm
I just put a new motor in my car. 408 12.2:1 with ls3 Frankenstein m311 heads, 1050 carb, single plane intake, msd 6010 box and I’m having problems with a misfire right around 6000 rpm in high gear. Br7ef plug gapped at .035
It don’t brake up in the burn out box, it leaves clean of the brake at 4500 rpm, shift it at 7500 and it drops to 6100 or so and it starts braking up, tach starts jumping around erratically. I had a SBE 5.3 in the car before I put the new motor in with the same msd box and had no problem with the box.
Ive tried new plugs, checked the msd box ground, swapped the coil packs, ran timing anywhere from 27 degrees to 34 degrees all the same. AF is right around 12.2 at the moment but I also tried adding and taking jet out and still the same.
Any help would be appreciated
Old 11-13-2021, 03:16 AM
gametech's Avatar
You have to do things methodically to diagnose a problem. You reduce the timing to eliminate that. 20 degrees will net you no power, but would eliminate a variable. Do the same with the plugs. .022 will not be ideal, but should eliminate spark blowout. drop the rev limit until you quit misfiring, etc., etc, until the motor clears up. However, before you do all that, check your float bowl and fuel pressure, because it sounds like a lean problem with a bigger motor. That is usually a fueling issue.
The following users liked this post:
G Atsma (11-13-2021)
Old 11-14-2021, 05:44 PM
Ive tightened the spark plug gap, I’ve added fuel I’ve taken fuel away, I’ve swapped coil packs, I’ve swapped plugs, I’ve swapped plug wires. I swapped out the cam sensor for another new gm sensor and the car wouldn’t start at all, put the old one back in and it fired right up.
When going to the front mount cam sensor does anything with MSD 6010 does anything else have to be done other than the ext. harness? My cam sensor has the factory pig tail harness on it.
Old 11-20-2021, 05:12 AM
gametech's Avatar
I have not done anything with MSD in over 10 years, so the only thing I have left to say is I don't know. Sorry. That being said, it really sounded like your original symptoms were a leaning out problem. Are you sure you don't have a clogged filter or something?
Old 12-13-2021, 07:10 AM
SCJW's Avatar
what’s your valve train setup?
Old 12-14-2021, 11:23 AM
LilJayV10's Avatar
A reluctor wheel with excessive run out or too much thrust end play will cause this.
This is worst case scenario of course and hopefully that's not it.
Old Buzzard (12-23-2021)
Quick Reply: 408 misfiring at higher rpm
