1997 c3500 454 back to carb or TB.
Hi all, I’m tech tired. Always wanted a carbed LS 454. My intake manifold developed a coolant leak so I’m wanting to go carburated but the transmission issues scare me. I know modern FI is very reliable…until it isn’t and that’s when the diaper rash begins and I just want gas/air/spark then put it drive.I had carburetors in past so tuning jets and choke is not a problem. My L480E shifts perfectly so I hate to go to a different tranny but will if I have to. I have some questions if you all would please.
1) what’s the best alternative automatic transmission alternative should I get ?.
2)I would settle for going older throttle body, if I get a donor or summit new throttle body could I still use my tranny ?.
thank you for any help, other thoughts.
The following users liked this post:
strutaeng (07-23-2023)
But to answer your question about the transmission: the 4L80e is really the only option you have. GM didn't make any other heavy duty transmission for these generation of trucks. Unless you want to go with a NV4500. You can get a stand alone controller to control the electronics portion of your transmission.
Savageyote (08-26-2023)
The 97 454 is a good motor. I’d strongly suggest keeping efi, new ford injectors and convert the ecu to 0411 and it will be a good reliable motor
my 97 454 dually with the smallest cam comp sells and 0411 with basic tune gets 11.5-12.5 mpg.
I am currently running a carbureted LS powered 68 Camaro, I love it. My next build is a 66 chevy II and I am planning in a 4l60E for a trans, along with carbureted LS. The plan is to use a terminator x max for the ignition side of my motor, plus the transmission control. All I will need, according to my research and what I was told, is to buy a throttle position sensor so the computer will "know" where I'm at %wise for the throttle to tell the computer to control the trans.
You could run a carb intake with a Holley Terminator X MAX stealth which is a throttle body EFI setup (4150 style) which will also control the transmission. It will look identical to a carburetor, you wont have to mess with your fuel system much and you can tune for any modifications you want to make fairly easily... but there not cheap...
The following 2 users liked this post by Ls7colorado:
G Atsma (07-26-2023), Savageyote (10-11-2023)
