LS carb set up question
I'm trying to find a used msd 6ls or ls series box or an alternative. 5.3L gen III, 4.8L pistons, cam motion .639/.600 lift 112lsa, Eddy single plane, Holley 770cfm carb, built th350 with 9in Coan 4k stall.
When mentioning a cam, duration is WAY more important than lift or LSA, especially when figuring piston to valve clearance.
I know all about PTV clearances and it wasn't relevant to the question I asked about looking for a used msd LS box. I've been building engines for a long time. I appreciate the input though.
I get and appreciate your point, it's just that cams are "known" more by duration than lift. "We out here" still have no idea which cam you are using.
