Timing for Carbed 416 LS3
Hi,
New to the LS game... I've been doing road race carbureted SBCs for a few years and always ended up the distributor locked out at around 38 degrees. I understand that LS motors require significantly less timing. But that carbed LS motors like a bit more than EFI ones.
My build (in a road racing stock car):
416 LS3
11.5:1 compression
Ported LS3 823 heads
243/258 @ 0.050, 629/621 lift, 109.5 LSA
Edelbrock Super Victor 4150 intake
Pro Systems 1000 CFM custom carburetor
100 octane fuel
Not running a MAP sensor.
My cam guy gave me a good set of baseline instructions for the timing on this LS3:
Thoughts? Suggestions?
Thanks,
Sal
416 LS3
11.5:1 compression
100 octane fuel
- CRANK 0-500 RPM 17*
- IDLE 500-1500 RPM 38*
- TRANSITION 1500-2200 RPM 34*
- 2200- TO MAX RPM START AT 28* AND GO FROM THERE
Thanks,
Sal
Look in the sticky section, a lot of good info there. What you show is too much down low and probably not enough up high. The high is a safe starting point and tune from there. Your low rpm timing is too much IMO. 12-14 cranking, What ever makes it happy at idle, then ramp up to all in at 2200.
