Overheating/Cooling Problem
It still overheats, the fans are running fine, the radiator seems ok, the hoses arent that bad but could be replaced. The only thing that is left is the waterpump. Do you guys think that it can be the water pump or is there something else I am not thinking about?
Also the display on the factory radio was working during the day but now the light is off, what can be causing this? its just the display and also the lights on the shift box
ill keep you posted Trending Topics
It very well could be a Head gasket, But air in the radiator could also be the problem....
doing an overhaul on the motor with forged pistons etc all the internal work and bore to a 383
The thing that boggles my mind is that all my air sensor codes went off today including TPS and stuff Im not sure if its because it got too hot or what, but also it reached almost 280 and when I turned the Z off it wasnt bubbling or boiling which is weird
Problem solved... Now to do Tranny, Suspension and brakes and start the motor rebuild process... 383 here we come
