"Security" light flashing in Dashboard... and Camaro wont start.
The problem that I'm having is with my 1999 Camaro. I recently changed the Ignition Lock Cylinder. My car wont turn on because the "security" light if flashing. Im planning on trying to give a VATS BYPASS MODULE a try.
The seller asks for a key code (from 1 to 15). The new Ignition Lock Cylinder's key has no resistor pellets, its just a plain key. Does that make a difference? Will a VATS BYPASS MODULE like the ones that are being sold in ebay do the job, and make my engine start?
(http://cgi.ebay.com/ebaymotors/Vats-...Q5fAccessories)
Thank You for any help or advice you can give me.
If GM installed one you should have been given a new key with it.
If you want to start your car you can install your old one. ohm out your key get some 1/2 watt resistors to match your key and sodier them into the wires going to your pcm.
If you do a search there is a ton of stuff out there for it. I just did one in my friends TA it was up and running in 15 minutes.
