Ls3 cable throttle body
i tried searching and didnt really get anywhere. does anyone know some places to get an ls3 4 bolt throttle body for somewhat cheap, like under 250?
Curious as well. Would this solve the problem? http://www.ebay.com/itm/220819527995...84.m1423.l2649
Thinking this might just let me use my ls1 tb on an ls3 intake? Edit- nevermind, looks like it works the other direction.
Re edit - maybe this one - http://www.ebay.com/itm/LS1-LS2-adap...item336a6e9f99
do not use the ebay ones I have heard they have issues with the sensor holes being the proper size and there is no fix if you get a bad one.
best I have seen is a Nick Williams 92mm tb cable drivin for 329 at the WS6 store.
only way your getting cheeper than 300 is used in the threads. do yourself a favor and get a good quality TB after all it is part of what helps your engine perform like it is suppose to.
hope this helps, this guy is doing a bad *** build. he has a lq4 6.0 with an ls3 top end.
https://ls1tech.com/forums/conversio...69-camaro.html
this is from his build, hes a nice guy. if you ask him a questioin about it he will answer.
Up top is an LS3 intake complete from a 2010 Camaro I purchased off of Ebay with 50 miles on it. Shipped to my house for $277. It came with the intake, injectors, fuel rails, bolts and the rubber gaskets. All like new and in perfect working condition. I am using a single line from the rear mounted regulator so it worked out perfect. The throttle body is a Professional Products 96mm. It came with the TPS, spacers, and gaskets for around $250 shipped.
