T5 5 Speed Manual Capabilities
Hi ls1 tech guys,
I’m planning on putting a Borg Warner T5 out of a 1983 Camaro Z28 in to my 1984 Camaro z28(my Z28 at the moment has a 700r4), but I have A modded 350 Goodrench crate motor (about 310HP/370LB-FT). Will the 1983 Borg Warner T5 take that much power?
NOPE! World Class T5's only handle 200-250ish, your gonna blow it up if u beat on it. i hav a 98 with a T5, i looked into T5 builds and you can get one with the stock gear ratios that can handle 300-350 for about $2000
I would skip directly to a T56 setup from a LT1 to run on your GEN I smallblock... A NWC T5 will fetch 300-500$ on ebay complete from flywheel to tailshaft. Use that to start saving 1-1.5k for a T56 swap.
