3800 series II problem, any help?
I have a 99 camaro 3800 series II v-6. Car runs fine until it reaches normal operating temp. then shuts off. It will restart but dies immediately. I have checked fuel pump and replaced fuel filter, getting plenty of fuel. Checked coil packs and module all are fine. Don't know what else it can be, any suggestions? Thanks
LS1Tech Premium Sponsor
Did you have the ignition control module checked on one of the fancy new DIS checkers??? They need to run it several times in a row to get the heat in there it needs to be an accurate test.
How'd you test the coils?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
