steering column experts?? HELP
so i have a msd ls1 starter been in an working perfect few months now., this weekend i tinted windows limo, played hell an had a headache but installed the complete energy suspension kit front to back.(kill engineer at GM that put the bolts in back side lower control arm!)
i replaced the turn signal cam an tightened all the loose bolts in my column, key cam seemed tighter than normal , went to start an wouldn't disengage starter solenoid. So i pray my flywheels ok, the starter is rebuild-able.. so where do i look an what should i do in the column? I hear theres a rod or switch or something of that sort in the column for that.. did i just way over tighten the screw that holds the key section in?
email or call would be awsome
leovascik at aol . com
or eight one zero 956 eight 57 one
leo
leo
ok so i ran test light down to the starter, let my friend do the ignition movements, not the column, bummer,, ended up my msd ls1 aps starter gave out.. awesome warranty threw summit racing though.. have a new one already. when warranty is out that aps is rebuild-able :-)
