Possible HP?/cam choice
I'm going to buy a 2002 camaro SS, with less than 50,000 miles, BONE STOCK...
With the following mods:
1. P&P throttle body
2. SLP lid
3. stock ls6 intake
4. ls6 heads
5. comp cams 232/234 .595 .598 112 LSA
6. TSP hardened pushrods
7. comp cams 918 springs
8. kooks headers/full true dual magnaflow x pipe exaust
400 hp possible? This look good? How does the cam look for this setup?
2. SLP lid
3. stock ls6 intake
4. ls6 heads
looks like a sweet setup..almost exactly like mine..think my cam may be .003 bigger..mines a .598/.603.. Add a 85mm mass air and I made 441hp with 4.10 gears
My heads are a custom stage 2.5 from Texas speed... but I dont think youll be too far off with a good tune..415-430hp range..if your auto maybe just slightly less
you can $save money, and keep the stock TB, its good to 500 hp and the maf also, more money in your pocket, i have a 02 ss with LS6 heads, comp cam 228/232 with 600 lift on both sides 112lsa, stock tb, stock maf, stock injectors, stock fuel pump, stock intake manifold, dyno 430rwhp, so check into, before spend your hard earned money, also stock #243 heads, no port, they make good hp right out of the box.
