My 2000 Z28 M6 Build Thread for 2011
#47
most changes will be minor but some before and afters. Cant wait to do the suspension and get the front end down. I swear it is a lot higher
next up is getting the air dam and hood on and under coating the wheel wells
also want to pick up a line lock w/ abs delete so I can get rid of that giant eye sore under the hood
#48
Went and got some Gas tonight.. So sweet.. This this thig behaves so well Just off
of Brandons Quick Base tune when I brought him the ecm. Cant wait til after the dyno tune tomorrow night
http://www.youtube.com/watch?v=Ufu2UuzAwDU
#49
#50
got my Dyno tune
The car made enough power to make me happy and The driveability is outstanding.
still have a few minor issues to fix along with brakes and suspension but its on the road
the look on Brandons face was priceless
the shop had a surprise visit too.. some people LOL
http://www.youtube.com/watch?v=1QBgMTfJwkg
and a pull
http://www.youtube.com/watch?v=rmPzHfG66hs
and a pull
#52
Me and a buddy got the rear end in with the new gears.. What a PITA.. It was easier to do my motor swap from the top alone with the trans still in the car the it was to get the ******* wilwoods off the old rear.. Steel bolts in aluminum brackets and calipers FTL..
all the bolts snapped off and were seized in the caliper.. took about 6 hours just to get the brakes off and get new bolts.. the rest was a cake walk lol.
once we got the old rear end out we were able to swap backing plates and get it all buttoned back up..
in the future I will just swap the gears with the rear end in the car lol..
went from stock 3.42 to motive 4.10
speedometer is off by 11 mph says 55 and I am goin 44 but feels like it will be fun still got a heat cycle to go before I can play
stock backing plate
backing plate for the wilwoods
Thanks Again for all your help Steve
stock backing plate
#54
ok so trans is at Finish Line Transmissions should know more in a week or so. in the mean time I swapped out the solid motor mounts and went back to stock ( couldn't stand the custom ORY slappin the floor). Pulled the wilwoods off which includes the backing plates and spindle/knuckle, They should be getting picked up today.
I still need to get the front QA1's and install the them with the rear QA1's I already have, get new QA1 300# front spring, pick up a borla xr1 and get that on and get some stock brakes with drilled and slotted rotors.
Is this normal for new gears after about 1500 miles?
I hope to have it back on the road and a few weeks but we shall see
#56
Are these the Deposit "Euro" headlights that amazon sells? I see they already come whistler modded, but did you mod them even more? Yours look much darker than the ones I see. I like them
#59
http://youtu.be/Pj7NzyUp8hA
http://youtu.be/TBvAryTTv6Y
I still want to swap over to the QA1 300# springs in front, put the Dana S60 with some 4.10s in the back and a harwood hood this winter. The front needs to come up a bit also imo.
