Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
lq9 99 camaro build questions
Old 07-18-2011, 03:05 AM
kalildude's Avatar
Default lq9 99 camaro build questions
ok so i need your guys help. i have right now is a 99 camaro ls1 with a ati p1-1 procharger, full suspension, roll cage, alcohol injection, 12 bolt with 4.11, th400 fully built. now i spun a bearing and now im looking into building a lq9 motor i need help with what is a mild boost cam that sounds good and i need help on what kind of heads to get. i also wanna know if you used a lq4 and or a lq9 and how much power you made and with what psi your using? what worked best thanks.
Old 07-18-2011, 03:09 AM
COOKIE MONSTER's Avatar
What are your plans for the car? Is this something that you're trying to take to the tack every weekend or is it something you just plan on cruising with as a street car?
Was your old motor fully built? Virginia Speed built my LQ9 370. I use ETP LS7 heads, and a custom grind cam.
Old 07-18-2011, 03:15 AM
kalildude's Avatar
motor was a stock ls1 with injectors lol. daily driver *** kicker lol. but i have a little budget i wanna have stock internals. but i want to be around the 10 psi area?
Old 07-18-2011, 03:16 AM
kalildude's Avatar
what were the specs on your cam?
Old 07-18-2011, 03:17 AM
kalildude's Avatar
im aiming for around 600 hp or a little more idc what the boosted is at
Quick Reply: lq9 99 camaro build questions
