1997 Camaro door panel light
I have a small light bulb mounted on the rear of the door handle panel. It emits light from a small hole drilled in the panel. There is no listing for this bulb in the manual. Could someone please tell me what the GM part number is or what bulb I can use to replace this? Thanks.
Jim
Jim
Go to the parts dept at your Chevy dealership and they can order them. They are only a couple of bucks. When I changed mine the old bulbs were a pain to pull out. I had to use pliers and ended up breaking the old bulbs but they came out.
