Just got a 1994 Z28 a few questions.
Well like the title says I just recently got a new car, my first NON-Ford. I traded my 1994 Mustang GT for it, was very sad to see her go but I figured too good of a deal to pass up. I traded the Mustang for the Camaro and got 700$ cash in hand. Heres the pictures ( Questions follow...)
![](http://img819.imageshack.us/img819/4747/img0528oe.jpg)
![](http://img267.imageshack.us/img267/6487/0125131133a.jpg)
Ported Heads
Ported Throttle Body
Full MSD Ignition
BBK Intake
BBK Headers
King Cobra Clutch
3.73 gears
Subframes
Drag springs, with LCA's and Strut tower Braces
200,000+ Miles
New Car, 119,000 miles
Intake, Exhaust (Dumped), B&M Shift Kit, Stalled, Air Foil
![](http://img842.imageshack.us/img842/2429/56021510151397015875750.jpg)
![](http://img18.imageshack.us/img18/3453/download1ds.jpg)
Questions now:
My passenger window rolls up slow and sometimes stops when its cold out, if its warm out no problems. My oil gauge reads 0 sometimes and normal at other times, every time is reads 0 it says check gauges . How hard is long tubes to put on. I picked those up off a 96 Camaro for 30$ are they an abosolute pain in the *** or is it doable with some patients.
Ported Heads
Full MSD Ignition
BBK Intake
BBK Headers
King Cobra Clutch
3.73 gears
Subframes
200,000+ Miles
Questions now:
Doable with patients plenty of threads about header installs. You need a new window motor which is common....no help on the 0 pressure except the check gauges light is coming on just to tell you to look at your gauges.
I know with some headers its makes it a little easier when you un bolt the motor mounts and raise the engine a tad for some extra clearance when installing. The oil pressure may just be as simple as a sender, but check the oil pressure with a manual gauge fist to be sure it has it.
