94 Z28 need help
Ok, LT1 6 speed has fresh t56, and K&N cold air intake, thats it. It has started missing. It is throwing no codes, i took maf sensor off and cleaned, went back to running fine. Today it was raining, and I filled gas tank up. It was hardly noticable before I got gas. After, went to running like @^&*. Took maf off cleaned, still doing the same. Checked for vacume leaks hoses, intake, found none changed fuel filter and air filter. It does have the cat on it, I hear it rattle, so its going this weekend. Its my daily driver until I finish other project, and have no idea where to start. Thanks
Could it be the Optispark?
Thanks for the replies. Removed cat, and welded straight 3inch exhaust back in today. The cat had been hollowed out, which causes turbulance. Slight improvment. The MAF is next. Now for the optispark, I haven't checked real good, but its getting proper fire. I have heard complaints about the optispark and waterpumps leaking causing corrosion, thus ruining optispark. I have another idea. When it had rained and I was having the problem, i noticed insulation wet under hood slightly. It was from the seals of the factory bull$%%^ vents leaking. I wonder if the optispark problem is experienced mostly from that instead of waterpump.
