Do i have ABS on my camaro ??
Alright im new to the forum thing, and i have looked all over for answer to my question and cannot find it if anything I'm more confused. I am a new owner of a 2000 camaro v6. It is an auto. First i know i have the GU6- 3.42 also i know when i try a burnout only one wheel spins so i have a limited slip differential. I also have Anti Slip Regulation toggle on my car? So if anyone could give me more info or clear this up that would be great!
Pop your hood, on the left hand side behind the air box there will be a block with steel lines coming out of it, if you have that, you have ABS. My 2000 V6 Camaro had ABS, mine was base model with a 5-speed with manual windows so yours should have it!
