Story and build of my $300 Thirdgen
#63
Update bye bye stock rear end went and picked up a 4th gen rear from a 99 ss also got the aluminum driveshaft and torque arm paid 275 for all of it next fri will have a steering column coming. That is all.
#64
Is you go gears in the rear before you put the rear under the car?
#65
Plan on leaving the rear stock till after its running then probably 3.73's anyways motor mounts on torque arm cleaned up gauge assembly with led's started to clean the grime off the trans tunnel and wow that stuff sucks to get off killed my drill twice fully charged both times also got my afterburner third brake light wired up video below
#68
Just bought a 4l60 for $350 specs are Built by monster transmission. stage 2 setup with b&m shift kit and Hughes performance 3k stall tq converter. 2k on rebuild about 1300 from the car running
#69
Update ive bought alt and powersteering brackets have a new ls1/a4 harness on the way steering column should be here tomorrow also buying a fuel pump assembly tomorrow for lol $25:p also getting pre-bent fuel lines that is all
#73
Been a busy weekend steering column in, new ball joints, fuel pump with lines installed, new rear in, lca's bolted in, heater hose mod on rear coils, front coils cut one complete coil, a pillar done, nitrous press and afr ready to be wired up. Next steering linkage and brakes/ebrake. Btw having access to a rollback, lift, and tranny jack is very nice
#76
Alright moving on paint is getting delayed since I found a gfx for the front and needs a bit of work so going to wait till thats done then send it. Also gauges wired up. Oh and this is how the covers turned out really happy with it and figured out something pretty cool for the pcv hose system. Just bought a 411 ecu and a bcm with matching key so my security light will go away that is all.
Also heres my buddys project that ive been working on
#77
Update so far ls6 rails and injectors came, center console and hvac box came, bcm and key are on there way so the vats in the bcm will be happy have all the parts to redo the entire brake system sucks because ive made a lot of progress and it still seems so far away till its done ah oh well beginning of next month ill have a bit of money to throw into its never ending amount of parts got a few days off this week hopefullly it wont be to hot and can get some work done on it.
#78
Hey, Congratulations on your future son.
Car looks good. When you get a chance, could you show more about the motor mounts and what you had to do to the Kmember and anything else related to getting that LS to fit?
By the way guys....this guy would give the shirt off his back. Sent me some parts just for shipping.
Good dude.
Thanks again
Good dude.
Thanks again
#79
Hey thanks man and yea sure I can snap some pics tomorrow they retain the stock clam shell mounts that are bolted to the kmember. Front brake/steering is completely brand new need to tighten up the bolts and throw the cotter pins in finish cleaning/undercoat the trans tunnel set the front on the ground then move to the rear brakes then onto pulling the interior to cut a hole in the firewall for the hvac box anyways some progress pics
By the way in the third pic in case anyone wants to know what 2.5 tint looks like theres an example will wait to the car on the ground before I sit in it and decide if its to dark for me
