Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Story and build of my $300 Thirdgen
Old 07-02-2014, 12:46 AM
  #81
86_irocz-28's Avatar
Thanks man not much has gotten done lately been to busy with work and complications with wife being pregnant but got some stuff done on the car this week pulled the dash back out so I can cut the hole in the firewall for the ac system also figured why my turn signals werent working. Thanks to a coworker I got the vats for the bcm bypassed hes going to school for electrical engineering and did his like this two years ago whats cool is I can still unplug the connector if say I ever have to store it, works as a kill switch plus by using the connector I dont have to pull the key in and out causing wear on the contacts on the pellet.
Old 07-29-2014, 12:04 AM
  #82
So far ive bought and installed a cobalt steering wheel got a full brand new magnaflow exhaust system dirt cheap got my third brake light permanently fully installed also found the location that I wanted my scan gauge to sit oh and I also bought a new motor still a 5.3 but has 71xxx miles on it got it fairly cheap didnt snap any pics sitting at a buddys shop right now.
Old 07-29-2014, 10:02 AM
  #83
No_Quarter's Avatar
That 5.3 will be fun!
Old 07-29-2014, 11:54 AM
  #84
Just as fun as my other 5.3 plans the same
Old 09-01-2014, 02:13 AM
  #85
Alright havent had an update in awhile first finally getting back to the brakes rears have been completely replaced
and my ebrake now works after 8 hours of fighting with the cables had to use 92z28 ones, I just need to run the brake lines from the calipers to the porportioning valve then put the new brake hose's on the front then bleed the system and ill finally have brakes for the first time since I bought it. Also have decided I want my panels carpeted
couldnt resist taking a look at the exhaust I bought can't wait to hear that cammed 5.3 through it full 2.5 with 3in tips.
Firewall is almost cut out enough for the hvac box then the dash can go back in for the last time sucks I had to cut into the firewall after painting it not to long ago but itll be worth it on those hot days
have a new radiator for it while I had the car in the air I undercoated the trans tunnel. The motor has the fbody oil pan installed need to get the outside cleaned up and spray it btw what is this for?
Old 09-01-2014, 02:35 PM
  #86
kilrcady's Avatar
oil bypass.its missing its housing.Some tap it for a sender for a gauge.
Old 09-01-2014, 02:36 PM
  #87
kilrcady's Avatar
or an oil cooler
Old 09-04-2014, 09:06 PM
  #88
Really starting to get back on this new carpet installed hvac box finally done and installed my awesome switch panel from emblempros came today best custom piece ive bought. Also this weekend buying a few things from spohn.
Old 09-15-2014, 02:22 AM
  #89
More progress dash is back in tomorrow going to upullit to cut out a shifter after that center console can go in which is done and ready to go in switches installed and my color changing cup holder is done, extremely happy with how it came out. While im getting the interior finished the exterior is torn apart decided to replace the fenders bumper and header panel with brand new replacements oh and my stuff from spohn came still need to order more from them, as always pics!
Oh and the video
Old 10-08-2014, 06:30 PM
  #90
TPI TERROR's Avatar
Nice build .
What rear vie mirror is that off of
Old 10-08-2014, 08:45 PM
  #91
Originally Posted by TPI TERROR
Nice build .
02 tahoe I believe
Old 10-08-2014, 11:53 PM
  #92
Well so far ive got a bit done flip out stereo took a crap on me so bought a double din wired it up its a pioneer avh2600bt also got the new motor mounts in man these were a p.I.a to change iut also found out my front pass strut is blown bad to also cleaning up the new motor taped off the deck after cleaning it sprayed it car now has a shifter again center console is in herculined the roof to prevent it from ever rusting... I believe thats everything so far pics!!
Old 10-18-2014, 06:45 AM
  #93
Y2KFirehawk's Avatar
Awesome work. Subscribing!
Old 10-18-2014, 03:01 PM
  #94
Thanks man, double dins done installed also finally have the correct transmission pretty sure it needs rebuilt and needs the correct tailhousing but i picked it up for $200. Also drivers window is rewired with new relays and 10/14 gauge wire and for what i believe to be the factory motor and less than par greased tracks its almost as fast as my 08 maxima which is just wow im not sure if i want to put in a new motor I plan to grease everything up though. Taillights now have leds in them and there alot brighter at night
Old 01-20-2015, 01:16 AM
  #95
Havent updated in forever brakes are done got a shifter I finally like looks fairly factory to. Bought a trans rebuild kit and shift kit since im pretty sure 3-4 clutches are burnt out according to the guy i bought it from, also got a torque converter ls7 lifters and ls2 trays came, scored a brand new fender for $60 getting really close to being done just need pushrods/rockers/head studs/headers/windshield and have chad at the shop rebuild the trans then run fuel lines interiors back together for the last time the car wont be finished but will run and I can at least enjoy it while I finish the little odd and ends.
Old 02-23-2015, 12:44 AM
  #96
Second guessed myself on the wheel color so cleaned one off and redid it its hyper silver think I like it alot better also just bought a nitrous kit have all the russell fittings/hose to run the the fuel lines for the engine not much else has been done has just been to cold lately heres the comparison of the old color and new
Old 02-23-2015, 07:20 AM
  #97
01 CamaroSS SLP's Avatar
It looks like it's coming along nicely. Love the leds, it's a nice touch.
Old 03-07-2015, 01:10 AM
  #98
things are going to start picking up again weathers finally getting warm and I started a better job where ill make more today was nice enough out I ran my russell fuel line, detailed the entire interior minus the hatch area also jammed the car all I can say is artic white will look killer on this tomorrow ill run the feed line for the nitrous trans is off to be rebuilt I had a lil help today as well
Old 03-07-2015, 03:11 AM
  #99
Sickness7's Avatar
Car has come a long way... is a beaut
Old 03-07-2015, 06:26 AM
  #100
Looking good bud! I hear you on the weather it's actually going to be in the 40s here in mass next week.
Quick Reply: Story and build of my $300 Thirdgen
