I cant find anyone with the same problem
so as with alot of other people i had a problem with the turn signal on my '98 Camaro, i replaced the front left bulb and the fuse relay and it started working again! (woo!)
but now the flashing light on the left side stays on.. when i turn the right turn signal on it will turn off and the right will flash but when i put it in the middle to have them both off, the left one will flash..the dashboard indicator isnt showing that either of them are flashing but if i look at them after getting out of the car they are still flashing...
anyone know what might be wrong? they flash even when the car is off and key is out..
never had anything like it, but if it were me, i wud trace and replace everything between the bulb and the lever, a huge pain, but so is the symptoms u describe. or take it to someone.
