Power steering fluid mixing with coolant. Help
Well I got the ol coolant mixing with the power steering fluid problem. I'll search later tonight. On how to fix this. But if any body knows the best easiest cheapest way. Please let me know. Thank you all. Bret
LS1Tech Premium Sponsor
It sound like your power steering cooler is leaking into the cooling system. The easiest way to fix it is to just take the power steering cooler out of the system and purchase the upper radiator hose that is used without the cooler. Other than that you will need to trim a power steering line to length and you should be good.
If you search on here there are quite a few threads on this issue.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
LS1Tech Administrator
Received 1,492 Likes
If you look in the General Maintenance and Repairs section, you will find a huge sticky right at the top that covers this. Here is a link:
https://ls1tech.com/forums/general-m...g-success.html
Both systems will need to be flushed to remove the cross-contamination.
