Bought 1998 roller need help with harness
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/28687_a29a2a2cd91af67ad321b33cf7774670726ac966.jpeg)
I purchased a 1998 camaro roller my first 4th gen , and while I got the harness in a box I didn't get the PCM...so after reading I bought a 0411 and sent the harness off to get repinned...2,problems I asked the guy to label at least the important stuff ( crank , cam, tps, iac ect) he didn't and also there are 2 plugs coming through firewall but there are 3,plugs on the wiring harness,bulkhead connector?
This is gonna suck isn't it hehe...
Okay since it is a 98 you will have three connectors running into the cabin. The connector in question is the In-Line Connector C210 (8 cavities, White) instrument panel to engine harness, under the right side of the instrument panel, behind the knee bolster
Check the harness in the car behind the knee bolster and it should be there. If it is not trace from under the dash as the plug goes to the instrument panel.
Hope this helps.
Hope this helps.
Thanks Both of you.....
One more question ( yea right)..I got the factory preformed power wires..the lead down to the starter has the main power wire...and it also has the main battery ground...when I got under there I assumed the ground would just go to a starter mounting bolt or something else I would see but that's not the case I can't see a lug where it goes....
Wow what a learning curve...
I can't find a threaded hole near ( 2004 6.0l) but i also had thought about a motor mount bolt...
I pulled that starter lead back and and tried to run down the frame not long enough... I pulled em all back and run under the evap lines and got just enough to plug oil level sensor in the rest was fine...
Thanks...
Could someone take a photo where they main power lines run over to the distribution block?
Thanks...
