My 99 Camaro build
#61
Changing directions on the trans. I ended up with a free powerglide and after doing some research. They can be great behind turbo LS cars. Plus, they’ve been around forever and have proven themselves in the race seen. I’m debating on using this just for mock up or attempting to rebuild it myself. From what I hear and have been reading they’re really easy to build.
Also, on the update. Cleaning and fitting the stock wiring harness. Definitely got a boost of motivation now the engine is in the car. Still scratching my head on what manifolds to run. I’m even thinking about biting the bullet on the Huron twin turbo hot side kit. But I don’t like where they place the turbos.
#64
I'm a welder by trade, DON'T TRY TO LEARN TO WELD ON A CAGE, IT'S THERE TO PROTECT YOUR LIFE, NOT A SCIENCE EXPERIMENT.
#65
yeah, I ended up taking the car to a friend garage who knows how to weld. It was a great learning experience, but there’s no way I would’ve been able to do it properly the first time. I am practicing on little jobs, like making brackets to hang the intercooler and relocating the radiator. All that is challenging enough.
#66
Right on brother, thats the spirit. I saw that and kinda freaked, glad you let your buddy help you, no sense in being a statistic. Car looks good man keep up the good work, if I was closer I'd bring the beer,
Later Mike.
Later Mike.
#67
Thanks, for the positive feedback. 👍 I have a goal to fire this thing up around February March and on the road by next fall for the OC md car show. So, hopefully this build will start picking up speed. Just need to get through the holidays. Lol
#68
I hope you share a clip of your breathing dragon when it comes to life. Nice build there! What exhaust manifolds did you end up going with?
#69
they are made by XS Power. I bought them off of Amazon. They say they’re specific for the 4th gen fbody, but I had to dent the driver side a little to clear the stearing shaft (Not a lot). They were under 300 and the quality is surprisingly good.
#70
why doesn't anybody make headers we don't have to dent and not be stupid expensive
#71
I agree, but I guess I’ll take these over paying a grand for a “perfect fit”. After watching the roadkill episode where they dented the headers and lost no power, I think I can live with a small dent and fatter pockets. Haha
#72
Update!! Still at it. I haven’t posted anything in a while due to it just being me trying to figure out the wiring. I’ve been working on rewireing the car to work without the BcM and so far have been successful at getting wipers, the stock cluster, power windows and lights to work. I have both the hot side and cold side of the turbo mocked up. Just working on how to get the 4” downpipes to mate with the dual 3” exhaust. Slow and steady. Hopefully this thing will be firing in the next few months. All I need to do now is build a fuel system and button up some electronics. 🤞
The following users liked this post:
99MERICA (07-14-2019)
#73
It looks awesome. This is what I plan on doing with my 99 V6 car as well, but slower, and in stages. I plan on getting a 5.3L in and driving, then maybe adding the Huron speed twin kit, and building a forged motor as funds allow. All while doing things like the tubular k frame and other related things.
#74
Captain,
I’m new here and this is one of the first threads I clicked on. You have done an amazing job thus far. I can’t wait for the continuation to see everything finally come together. I just got a 00 Z28 and am only pulling the LS1 to build up and replace the stock 4L60E with a T56 setup. Nothing like what you have accomplished but you have given me even more motivation.
Keep up the the outstanding Work!
Mat
Mat
#75
Captain,
Mat
Mat
Z28_Demon (07-23-2019)
#76
I have a build thread started, but so far I have dragged it home, shoved it in the shed, bought an LS factory K member and pulled the engine out of a Yukon for it. I’m trying to decide if DBW is worth it since I’ll be running a terminator in it most likely and they don’t use the truck peddle or early truck DBW throttle body so both those parts I have are useless with a terminator.
#77
So I finally pulled the plug and purchased a big item for my build. I ditched the powerglide and went with a turbo 400 with a transbrake. Anyone have any recommendations for a converter? I’m looking to be in the 3800-4000rpm stall range.
#78
Ordered the fuels system, started mocking up the down pipes, and purchased a center section for my rear. Tired of sitting on this project. Goal is to have a running and driving car by May 2020. Let’s get at it.
PS, don’t be too harsh on my welds. (LoL)
#79
Things have been slow, knocking out wiring still (actually rewiring). I didn’t like the original rats nest that I created, so I cleaned it up and created a PDF of the wiring for my car, to make it easier in the future if I end up having issues. So I created this relay panel, which cut down on the wire mess I had. I’ll take pics of the final product when done.
I also bought a TIG machine and have been teaching myself to weld. I finally had an ah hah Moment the other day and am able to weld Aluminum (woot woot!). Now the welds are far from perfect and I’ll probably redo them when I get better, but it’s a step in the right direction
i also, just picked up a true dual axle dump setup for $150. My fuel lines, Hobbs switch, and walbro 450s came in. So I’ll be throwing Them in soon. Good progress
#80
Ok, I’ve hit a road block. I’m trying to wire the tach signal pin #10 red connector from the PCM to my stock gauges. These are the stock 99 V6 gauges. I’ve looked at the pin out schematics for the gauge cluster and I don’t see anything that says tach input. How do the guages receive their info for RPM read out?
